Viewer ignores EXIF Orientation
Hi there, i just realized DOpus 13 ignores the EXIF Orientation (e.g. jpeg/webp images), despite being configured to obey it (and been that way since v12)
It's just me, or a regression in v13 ?
Check with these images: GitHub - recurser/exif-orientation-examples: Example images for the various EXIF orientation flags, in both landscape and portrait orientation.
It seems to work OK here. If I select an image file in thumbnails mode and adjust the rotation field via the metadata panel, the thumbnail updates each time, and double-clicking the thumbnail opens the viewer with the correct orientation.
Weird, dunno what's going on here.
Will send you a PM with an screen recording.
Ok, got a handle on this. The images that don't work have EXIF orientations that also require the image to be reflected about the Y axis. This is something Opus has never supported, although there's no reason not to (other than I don't think we've ever actually come across an image that was stored like this).
We'll make this work in the next update.
Yay, everything is working fine now on the latest beta, thank you very much :slight_smile:
