Sometimes (can't catch the cause) double click works wrong on divider between dual panels and viewer pane. As far as I understand it must divide all the panes (including file panels) into equal width such it works on divider between dual panels. See attached video. Don't mind on cursor offset in video. It isn't bug of DOpus, but the capturing software.
Double-clicking the viewer pane divider will try to reset its width to the way you saved it in the Default Lister.
If it's the wrong size for you, resize it, then use Settings > Set As Default Lister (or close the window, if Opus is configured to save a new default lister whenever the window is closed). That size will then be used in new windows*.
(*Unless you open a layout or apply a style, since those save their own panel sizes.)
