Hi!
when viewing a html file in viewer pane I get a different picture as opposed to opening the file in e.g. Chrome, pls. see:
The line indentions are different for example.
DO obviously uses IE 32 bit which may cause this different picture.
Using Windows Explorer for verification is not possible or accurate, since the Explorer does not fully display the html content. For security reasons it is blocking those little symbols at the beginning of some lines.
Can I force DO to use any installed edge viewer for example? I assume using Chrome for inline preview is not possible at this point.
