Viewer pane not resizing properly (Windhawk / Slick Window Arrangement)
DOpus 13.10.3
Please give more detail.
press F7,Drag the mouse to change the width of the viewer pane
元数据窗格与查看器窗格同时显示时,更改窗格宽度不会发生重绘错误。
When the metadata pane is displayed at the same time as the viewer pane, changing the pane width does not cause a redraw error.
I don't see any problem when I do the same thing.
What is displayed inside the viewer pane when this happens? Is it a third-party viewer?
is text viewer
Can't reproduce that, sorry.
From your screenshot it looks like the viewer plugin isn't resizing when it's told to. It's also missing the scrollbar at the bottom as a result. But I am not sure how that can happen, if it's the standard text plugin and hasn't been modified.
amped_OEM.7z (4.0 KB)
Try to view these files
amped_OEM.nfo
amped_OEM-1200  (Unicode).nfo
amped_OEM-1201  (Unicode - Big-Endian).nfo
amped_OEM-65001 (UTF-8).nfo
我认为是text viewer 的 RichEdit 控件的渲染问题导致的,尽快改进吧
I think it is caused by the rendering problem of the Richedit control of Text Viewer. Improve it as soon as possible
我在windows 沙盒中全新安装 DOpus 13.10.3 也无法复现这个问题,感觉问题出在我的系统上。
I installed DOPUS 13.10.3 in Windows sandbox and could not reproduce this problem. I feel that the problem is on my system.
找到问题所在了,我安装了 windhawkSlick Window Arrangement,禁用了 Slick Window Arrangement 插件后 DOpus 正常了.
I found the problem, I installed Windhawk and Slick Window Arrangement, which disabled the Slick Window Arrangement plug -in. Dopus is normal.
I'm surprised they found a way to break positioning of a child window like that, but alternative window managers have caused some strange problems over the years.
