Viewer Pane - Scroll images
Continuing the discussion from Directory Opus 13.22.1 (Beta):
But has anyone tried this option?
If I disable it, zooming with the mouse wheel works. However, when I enable it, scrolling between images doesn't work.
Scroll in this context means pan around an image that's larger than the window, it doesn't mean move to the next/previous image.
