I've not noticed this before but when viewing the contents of a CD or DVD it seems to be using the system view, like when viewing the desktop, control panel etc and not using dopus. Has this always been the case?
It means I can't use power view or flat view etc and all the other benefits that come with dopus views.
oh. Yes i've just used the built in Vista burning engine to burn some files onto a CD. It was when I put the CD back in to see if it had burned ok that I noticed this problem. So can I still use the Vista burning engine and also get back my opus views?
Just read the description for the second option, so I think I just need to turn this off and i'll still be able to burn CD's. Guess I should have done that before I posted above. Thanks Nudel.
