Viewing images in library problem
Hello,
  1. has anyone noticed when viewing multiple images using the dopus viewer of images within a library pressing next does not work? Initially it shows the forward arrow button and the total number of images in the directory, but after pressing the forward button it greys out, the same image stays in the viewer and the total files changes to 1.
However, if hte directory is moved to a non library then it works fine.
Had a search through the forums but couldn't find this.
  1. Also, has anyone noticed it takes quite a lot longer moving files/folders within the same harddisk in 10 vs 9? In dopus 9 (and explorer) it's instantaneous, whilst in 10 the dialog box comes up.
Thanks
1 is already fixed in the beta versions you can download
2 is probably either folder name localisation or extra file metadata being copied. You can turn bith off. There are recent threads about both. Shout if you can't find them. (I'm on my phone so it's a pain to dig them up.)
BTW, please also see the FAQ on 'one question per thread'.
Thanks for your help.
Sorry, didn't know about the 1 Q per thread.
Do you happen to know if the second question might be addressed somewhere?
Thanks
Ah, sorry, just realised you addressed both questions.
Thanks!
For the 2nd question:
[ul][li]Turn off everything in Preferences - File Operations - Copy Attributes
[/li]
[li]Turn off Preferences - Folders - Folder Display: Display localized folder names (Vista and above)[/li][/ul]
Then check the speed again.
If it's still slow, make sure no window is viewing the destination folder. (If that was what caused the slowdown, we can look into why; most likely something is taking a long time to inspect the new files as they appear in the folders; e.g. a video codec might be doing something silly.)
Thank you Leo!
Works perfectly!
Hello again,
does anyone know where one can find the beta versions?
Tried through the main download page link but am redirected to the forum and a message: "The forum you selected does not exist." even though I'm logged in.
Thanks
There's a link in my sig.
Thank you muchly.
