When adding color on filetypes, Dopus must be restarted
Hi,
I have added a color on file type groups. Yellow for archive (.zip+.rar), green for documents.
When i add an extension in the Documents file type group (for example .txt), the context menu is correctly the one for Documents, but the color doesn't change. I have closed and restarted DO and it's ok now.
To reproduce this, try to set a color for a file type group, add an extension to it, and see if a file with this extension has the correct color. It should have not changed.
I'd like someone to see if that's me or a real bug before sending a note to the support :slight_smile:
Well, I saw it, but then I immediately worked around it. Now, I cannot even reproduce it (at least not with the same file extension and File Type Group).
You can workaround this by:[ol][li] Open the File Types Dialog.[/li]
[li] Edit your File Type Group.[/li]
[li] Add your new file extension.[/li]
[li] Save the File Type Group.[/li]
[li] Edit your File Type Group a second time.[/li]
[li] Disable the override the default display colors option.[/li]
[li] Edit your File Type Group a third time.[/li]
[li] Re-enable the override the default display colors option.[/li][/ol]
The colors should be set correctly.
Nice workaround :slight_smile:
I'll make a small request, just to avoid all these steps when people want to add colors to their files
