I does work, although you are not able to double click ordinary files on the desktop (if you use the desktop for files) then a new lister will start instead of that file.
I will try that command line option later when I am at home.
I tested the command line option now, and when dopus.exe is not running and I start dopusrt.exe with the command line, I can double click my desktop to start dopus.exe and open a lister..
Although when dopus.exe has started it doesn't work to double click any more (seems like dopus turns the doubleclick feature off when started...
But if I start dopusrt.exe with the command line after dopus.exe is started it works all the time.
Yes I do have a Vista x64 installation on one machine, and now that the latest VMWare supports 64 bit guests on a 32 bit host OS it will be a lot easier.
Lack of computers isn't the problem, it's lack of time
I only get this problem when I log on to the PC locally when I log on through a domain on the same machine all is fine.
I was a little bummed to see that they took out replace explorer and double click to open in ver 9.2 for vista 64 bit I even went back to 9.1 because of it. double click to open a lister is my favorite thing about DO
