Window size is stuck
Hi. Somehow, my DOpus listers now default to a tiny, unusable size when first opened, so I have to drag them out to a usable size.
How can I reset the window size?
Thanks.
Go to Preferences / Layout:
[ul][li]On the Opening Listers tab, make sure the Inherit Size checkbox is turned off.
[/li]
[li] On the Default Settings tab, specify the size you want using either the numeric boxes or the tool that lets you grab an existing window's size.[/li][/ul](This is assuming you're not opening a Saved Layout.)
