WinRAR drag and drop to DOpus, unresponsive
I've discovered an issue when extracting a large RAR archive with WinRAR, specifically when the files are dragged and dropped out of WinRAR into DOpus.
While the files are being extracted from a drag and drop DOpus is unresponsive, but only the one lister the files were dropped to. Any other open listers do not lock up.
I'm not sure if this is a problem with DOpus or WinRAR - I'll let you decide.
I've supplied a RAR archive that you can test with. It contains 400 txt files that are 10mb each that total 3.90gb (txt files contain the text 'testing.' over and over). This was done so the extraction process will take a min or so and give you time to observe the freeze. Amazingly it's been compressed to only 2.03mb!
testing.rar (2.0 MB)
I also tried changing dragdrop_async to FALSE as described in another post (which was found while writing this from the window that pops up with other relevant posts) but does not make a difference.
Using the latest version of DOpus and latest WinRAR (5.40)
Thanks
What happens when you drag from WinRar to Explorer or any other program?
Same thing occurs with explorer, it becomes unresponsive. That would indicate it's not DOpus related. I need to keep in mind to test (applicable) things with explorer before I post here.
