I'm not arguing that our rename is necessarily as "user friendly" as some other tools, but to be honest it's not meant to be that dumbed-down. It's a power tool Most things are possible in one step (all things if you involve scripting) and if you're not up on regex or the finer points of jscript, don't forget all you have to do is ask here and we'll tell you how to do it.
Hi
One feature I use in explorer consistently all the time but can't seem to replicate in Opus is the ability to select all files in a single directory, rename any of them and explorer renames them all the same, with sequential numbering, e.g.
Folder:
File ABC
File 123
File XYZ
sdfsdfsdfsdf File
Select all
F2 to edit
Rename to New File
Explorer auto renames to:
New File (1)
New File (2)
New File (3)
New File (4)
I want to be able to replicate this in the same way with out having to click multiple icons or open a rename function as this is a basic function. If I can't do easily - multiple times over 3 or 4 files per folder - I have to stick with explorer
Thanks for your reply.
Explorer defaults the name of the first selected file, I press F2 then I edit that to what I want, then pressing enter will change the name of all the selected files, adding (1) , (2) etc. to any duplicate names/file types.
Will the script you provided default the name of the filename for me to edit or will it be blank - usually I do this to remove '.', superfluous text, etc. Can it be amended to include the filename?
See attached video for what I am trying to achieve/replicate
FWIW, we added an option under Preferences / File Operations / Rename to make inline rename (F2) work the same as it does in Explorer, without needing any scripts etc.
