Wrong channels count in the Info TIps
This is what I have inside the Info Tip Definition:
{name}
<b>Summary:</b>\	{mp3comment}
{thumbnail}
<b>Artists:</b>\	{mp3artist}
<b>Title:</b>\	{mp3title}
<b>Album:</b>\	{mp3album}
<b>Year:</b>\	{mp3year}
<b>Track Number:</b>\	{mp3track}
<b>Duration:</b>\	{mp3songlength}
<b>Codec:</b>\	{audiocodec}
<b>Bit Rate:</b>\	{mp3bitrate}
<b>Channels:</b>\	{mp3mode}
<b>Sample Rate:</b>\	{mp3samplerate}
<b>Modified:</b>\	{modified}
<b>Size:</b>\	{sizeauto}
<b>Info:</b>\	{mp3info}
When I hover the file this is what's showing:
MediaInfo reports the following:
Audio
Format                      : AAC LC SBR PS
Format/Info                 : Advanced Audio Codec Low Complexity with Spectral Band Replication and Parametric Stereo
Commercial name             : HE-AACv2
Format settings             : NBC
Codec ID                    : mp4a-40-29
Duration                    : 39 s 998 ms
Source duration             : 40 s 158 ms
Source_Duration_LastFrame   : -12 ms
Bit rate mode               : Variable
Bit rate                    : 42.0 kb/s
Channel(s)                  : 2 channels
Channel layout              : L R
Sampling rate               : 44.1 kHz
Frame rate                  : 21.533 FPS (2048 SPF)
Compression mode            : Lossy
Stream size                 : 205 KiB (73%)
Source stream size          : 206 KiB (74%)
Default                     : Yes
Alternate group             : 1
Menus                       : 3
here is the sample file:
Nightfall-audiobook_fx_2026_05_29_16-02-48.zip (265.5 KB)
Thanks for the report, we'll fix this in the next update.
