For information
there is an incorrect entry when switching on/off mark whole line.
normal: name
on = row
off = column instead of name
the entry with column is set as default.
For information
normal: name
on = row
You just need to take out the ,NameCol
that you highlighted at the end if you don't want it to do that.
Yes, this has already been done for the custom toolbar.
If this is changed in the standard toolbar, our translation can no longer be checked.
The small change means that the toolbar will not be updated automatically in the next version.
Therefore, this should be the default without the ,NameCol.
