Wrong transfer speed unit
When converting images, the process information shows wrong units (kb instead of mb).
This is for quite some time and not related to v12. o)
Thanks!
ps: Notification mails not arriving here for several days.
Missed the beta6 release, that's serious loss of information! o)
OT: Yep, also don't get mails.
What is the action or command you're using to get that to appear?
Is it a multi-line button/script or anything like that?
I see this:
It's this button code, I use it with CTRL + SHIFT held down most of the time. It has grown over time, should convert to script button within near future, but still get's the job done. There are two user defined commands involved to help with a confirm requester situation, I doubt that has something to do with it, but if you think it has, I can post them as well. The actual command showing the dialog probably is this one:
Image CONVERT=jpg PRESERVEDATE ROTATE=EXIF REPLACE=always QUALITY 85 NOLOSSLESS NOREDUCE
[code]@disablenosel
@admin
@filesonly
@useactivelister
// NOTHING pressed = Copy and convert files
// SHIFT pressed = Move and convert files and ask before delete
// SHIFT + CTRL pressed = Move and convert files and do NOT ASK before delete (quiet delete)
// Hide all unselected files
Select HIDEUNSEL NOPATTERN
// Deselect all the visible left files to process
Select NONE
// Now select only pics and movs again
Select PATTERN=".(jpg|mov|mp4|avi|rw2)"
// to eventually hide all unmatching file types and misc other stuff
// Now deselect again all pics and movs
Select NONE
// Select only jpgs
Select PATTERN="
.jpg"
// Copy-Convert the images
@keydown:shift
// Delete all the selected files. This is a USER DEFINED COMMAND to prevent a possible
// "Cancel" from stopping the script right here. We always want to proceed, regardless the
// user choice.
@runonce:ConfirmDeleteImages
@keydown:ctrlshift
// Delete all images in source without confirmation
Delete QUIET FORCE
@keydown:common
// Clear selection from jpgs
Select NONE
// Select all movs
Select PATTERN="*.(mov|mp4|avi|rw2)"
// Show the formerly not selected files and the automatically previously hidden & unmatching filetypes
Select SHOWHIDDEN NOPATTERN
// Copy them to destination
Copy COPYCREATIONTIME=yes RENAMEWHENSAME WHENEXISTS=rename
// Delete all the selected files, this is a USER DEFINED COMMAND!
@keydown:shift
// user choice.
@runonce:ConfirmDeleteOtherFiles
@keydown:ctrlshift
// Delete all other files (movies) in source without confirmation
Delete QUIET FORCE
@keydown:common
[/code]
Sorry, did not see your reply sooner due to the notification mail issue lately.
Thanks! Could be simplified to this in the end:
Image CONVERT Copy
12.0.8 will ensure the bogus byte values are hidden. (They are just a percentage really.)
Fine, sure the "Image" command I run is the same if I leave out all the parameters? I can't believe! o)
And I think just using "Image CONVERT" + "Copy" also won't do it for me, since I use this to copy/move selected jpg + raw and other files mixes in and I would end up with raws converted to jpg, right? o)
I mean the issue could be boiled down to that simple example. Obviously the commands do different things, but the differences are not relevant to the bug being fixed.
Ah, now I understand! o)
