Originally created as a demo for a modern Scintilla API wrapper for Delphi.
Source code now is available on github.
works correctly with Dopus 12/13 on Windows 10/11. There are no plans to support Windows 7 (at least for now).
Features
Display of source code files with syntax highlighting, similar Notepad++ / dosv
Autodetect encoding
Text search (built-in search + search dialog — accessible via Ctrl+F / Shift+Ctrl+F, then F3 / Shift+F3)
Jump to a specific line/character (Ctrl+G)
Highlight identical words (double-click)
Collapse/expand blocks (all, current block only, nested blocks within current block)
Configurable (like dosv) display styles for lexers
Support for Notepad++ theme files for easy styling (simply move the theme folder from npp++ to plugin settings folder, or import the desired theme-xml-file in “Settings/Styles/Import”)
Manage the list of supported file types for display (add your own / remove existing ones) - this requires restarting plugin / DO since the plugin explicitly registers lists of supported file extensions.
Copying content to the clipboard while preserving the current formatting style.
Copy both DLLs from the archive to %dopus_installation_directory%\viewers and refresh plugin list
Settings are stored in %appdata%\GPSoftware\Directory Opus\ConfigFiles, logs (if you enable them will be saved to %appdata%\GPSoftware\Directory Opus\Logs).
Yes, I’ve encountered this error myself. The core issue is that the VCL framefork doesn’t always work correctly within a DLL. However, this problem doesn’t occur in the WindowsPreviewHandler version - perhaps because it uses a different control. In any case, the error has been fixed; please download the updated version of the plugin from the first post.
For the future - if you encounter any errors—try enabling logging so that I can more easily track and reproduce them.
This problem Cannot exit preference state after custom settings is still the same. There is no problem in setting it from the right-click menu in the viewer panel.
Could you describe in more detail context how this happens and, if possible, attach a log snippet? The plugin settings dialog was opened via the settings button in the lister panel, from the lister context menu, or from the DO plugins settings page.
Oh, so that's how it is. I've only used (practiced with) the themes that come with Notepad++.. The error seems to be related to an XML validation issue, not the theme itself. The validation might be too strict. In XML, "&" and other "special" characters need to be escaped, but that hasn't been done here. I'll see what can be done.
I think I get it. The plugin settings dialog is accessed from within DO's settings, via the button next to the plugin's name. And after closing the settings, it becomes impossible to close DO's settings themselves. It feels like they're disabled.
yepp I think I figured it out. The plugin settings dialog is opened from the DO settings, via the button alongs the plugin name. And after closing the settings, it's impossible to close the DO settings themselves. Is that what you meant?
After viewing logs, i see that the viewer's UI thread is successfully displaying the settings, although it's running on a different thread (not the one where the VCL was initialized). Perhaps this is why EnablethreadWindows isn't called symmetrically (in end of vcl.tform`s.showModal) . I need to figure out what to do about it. The DO multithreading model for plugins turned out to be more complicated than I expected....
PS Actually, there's a similar viewer that works via PreviewHandlers Host, and it doesn't have these issues (at least I hope so ).
Yes, because the XML file is invalid. It contains unescaped "&" in the attributes. I'm not sure what dscintilla need to edit the theme files; they are only checked for syntactic correctness.
but in theory it needs to be fixed in generate-themes.ts by adding escape methods for reserved xml characters to node serializers. I also attached it dracula.zip (12.1 KB).
Later I will create issue for the dracula authors on github or you can do it for me)
To be honest, I haven't really tested the configuration file backup feature, and the opus API doesn't have a separate method for determining the plugin's configuration directory and list of configuration backup files, so it's a bit inconvenient.
