ZIP Problem - File is constructed although pressing abort!
Hello,
the following problem: Dopus 8.1.0.7 ANSI + German linguistic stack I marks a file - legal click - context menu - DirectoryOpus-ZIP - Add " to FILE NAME "-
In the following dialogue " to ZIP file add " I press cessation.
The file "File name" .zip is constructed with 22 bytes and also remains existing although the demolition(abort) - badge was pressed. This is not correct in my opinion.
Can you check this whether is also with You so?
Thank you
Stefan
