Because nearly tens of thousands of folders, so I need a good file explorer to manage these folders.
And in order to facilitate management folders, I have categorized and coded.
Through the network recommend buying your company's products.
I'm using Directory Opus software has been for many years.
In addition to Directory Opus 10 no purchase, 8 and 9 and 11 were purchased full version.
Start using Opus 8 and 9, the operating system is Windows XP 32.
Due to work demands I must be open several Directory Opus windows、Word、Notepad、Internet Explorer...
at my taskbar to facilitate my comparison.
Although I open several Opus at the same time, but I rename a folder at once.
Previously used Opus 8 and 9 to rename, I was also open many processing software Windows on the
taskbar, and each folder has at least three layers.
However, folders renamed was very quickly,didn't delay and didn't have to wait.
When upgrading to Win 7 64 and Opus 11, folders renamed becomes slowly and always delay, I often have
to wait for a long time.
I am currently using the OS is Windows 7 64, and my OS hard disk and data hard disk are two separate
hard disks.
My data hard disk size is 1TB SSHD and no partition.
At first I thought it was a hardware level is too low, so I changed some of my hardware.
Now my CPU is Intel Core I7-4930K, MB is GA-X79S-UP5-WIFI, and RAM are Kingston 2400MHz DDR3 16GB.
Even OS disk replacement for SSD and Data disk replacement for SSHD, but still there is no point
improvement.
I repeated the test, no matter how many Directory Opus on the taskbar to open, even if I only open
a Directory Opus, folders renaming on the first layer and second layer are very slow.
Instead, a folder of the third layer is the innermost layer is fast renaming, which makes me feel
very strange.
I have attached diagrams for your reference, only adds a word of English "A" in the first layer and
second layer, rename must wait some time to complete.
Figure 1 is first layer directory folders rename, about 15 seconds.
Figure 2 is second layer directory folders rename, about 40 seconds.
Figure 3 is third layer directory folders rename, about 2 seconds.
I have recorded video files, but was not able to post on the Forum.
Is there a way in a video posted on the Forum?
Because my English is not good, I may not be very detailed expression of the problem.
So if you can see the video file would be clearer to my problem.
Because there are many folders must to rename, so shorten the time of renaming is very important for me.
Could you please tell me how to solve this problem?
I am looking forward to receiving your reply, thank you very much.
