BUGS / LIMITATIONS:
- When one of delete or copy filter is enabled and you use Set FILTERS=toggle it turns them both off instead of toggling each filter
- Go {sourcepath$|..} FOLDERCONTENT does not show the parent folder, instead the current {sourcepath$} (maybe intentional for memory??)
- Hotkeys to popup menus will not work when focus is on viewer pane (viewing text)
- No option to send a toolbar under tab-strip (under tabstrip, right of folder tree, left of viewer pane) with Toolbar myTB STATE=???, but you can move it there manually from dragging in customize mode (shows up as <toolbar type="fdbottom"> in /dopusdata/ConfigFiles/toolbars.oxc)
- if double click on tab-strip to open new tab is enabled... when closing a tab via clicking the x on the tab itself and clicking again fast enough to be considered a double click will reopen a new tab when it shouldnt
- when dragging files in to a menu when oversized it doesn't scroll when mouse near lower part of menu (near the up down arrows)
- 'Close All Other Tabs' from tab-strip context menu while holding SHIFT closes all including locked.. So if Go TABCLOSEALL is set as a hotkey where SHIFT is one of its modifiers, it does close all including locked even when the FORCE switch isn't included with TABCLOSEALL
REQUESTS:
- Mouse wheel scroll (smoothly) oversized menus, toolbars too big for window, tab strip with too many tabs
- Multiple column menus
- Able to comment out lines in Advanced Command Editor
- Close a tabgroup (any tabs open belonging to group will be closed)
- Close last opened tab group
- Tabs show label characteristics, if one is set for current viewing folder, and any sub directories you switch to keeps label characteristic from previous, and is overriden when opening a sub directory with a diff label set
This would help when you custom name your tabs, the colors would help ID your location.
Nice program, Nice work!
DOPUS IS KING!!
