I have a small, but very annoying issue with Directory Opus 12.
On many occasions, the Tooltip sits on top of the context menu partially hiding my options.
Is there a way to make the Tooltip drop behind the context menu?
In 12.2.7, infotips are now disabled while using inline rename, which should fix the problem shown in the screenshot at least.
Do you see it in other situations not involving rename?
I can't remember if I saw it in any other situations, but I will keep an eye on it and see.
And thanks very much for that fix. That will be great. It used to happen quite often for me.
