Installed 13.5 and just copied some files and extracted some zip files and it looks like that Dopus takes 24gb memory.
Also it takes over 2% cpu all the time
Is there any debug logs for Dopus?
Memory leaks are usually caused by shell extensions or similar third-party components. How's how to track them down:
Those pictures where captured when Dopus was running about 30 seconds, after 2 minutes VMMap crashes (Not responding)
Could you save the VMMap output and send it to us? (File > Save As, within VMMap, then zip the result.)
VMMAP always crashes when I try to save dump. Dopus makes lot sof Heap allocation . Like almos 1gb in minute. I have Dopus installed on another PC there is no any issues with that one. Most of the other programs and plugins are same on those computers.
I think the problem started when tried to find duplicates on C: drive on the problematic machine.
Also updated to 13.5.2 beta, did not help.
Try going to coll:// and deleting any collections which are there (assuming you don't need them).
If you have a collection containing tens of millions of files, it might cause a lot of memory usage (not a leak).
Deleting collection fixed the problem.
Thanks
Arsi
