Image LOCATE=bing doesn't work. The Bing maps site opens up so far, but the location appears only in one of the fields. It isn't displayed on the map, as is the case with
the two google options. Editing parts of the coordinates doesn't work, only the whole number, which isn't optimal. For example, if i want change 53.12335 to 53.12345, i have to enter the whole
number after the period. Ideally, we could enter also decimal values, which would be calculated into the degree/minutes/seconds coordinates.
