Hello,
I am a trial user and have noticed a few issues with directory opus.
I tryed to send a support request but it didnt let me.
I tryed directory opus earlier this year but decided to try it again since this morning i got an email telling me there is currenly 30percent off.
I have moved my user data from c:\users\tim to f:\users\tim if i click on tim from the start menu it takes me to C:\users\tim and if i try to click on my documents for example it will say an error occured the system cannot find the path specified.
Happerns on vista and 7.
the other issue I have noticed is that with vista and 7 on C: it shows documents and settings instead of users.
It should show both Documents and Settings and Users in the C:\ drive, if you have Opus set to show hidden-system files & folders.
Vista and 7 have a Documents and Settings junction that points to the Users folder for compatibility and which will show up in file managers that don't hide such things. You can configure Opus to hide it, though. The easiest way is to turn on Settings -> Preferences / Folders / Options: Hide protected operating system files.
[quote="leo"]It should show both Documents and Settings and Users in the C:\ drive, if you have Opus set to show hidden-system files & folders.
Vista and 7 have a Documents and Settings junction that points to the Users folder for compatibility and which will show up in file managers that don't hide such things. You can configure Opus to hide it, though. The easiest way is to turn on Settings -> Preferences / Folders / Options: Hide protected operating system files.[/quote]
Ok fair enough what about my other issue?
if i click on Tim from the start menu it should take me to f\users\tim and not C:\users\tim
