In 9.1.0.0.2893.x64 the Abort button which appears next/under to the "Error occurred reading folder..." does not appear to be lined up correctly as it was before. Please see attched. You cannot read the whole word.
I know this is not a major issue but was hoping you could fix anyway.
The abort button next to the spinning blue thing is centred in the file display, while the modal error message box is centered on the entire window. So if you have two file displays of a certain size then the error box won't always obscure the blue spinner and Abort button, but it isn't supposed to.
Never noticed this before but I guess I must have rzized my window sizes since starting to test DOpus x64. Still, brings me to another point of, do we need the extra Abort button, does it serve a puropse that I am not aware of? Can it be disabled?
It lets you abort directory reads which take along time. The other abort button appears if there is an actual error. They're quite different things, and you only rarely see the non-error one.
