I am using another piece of software to keep track of backups, work, and projects. I want to be able to refer to a specific drive. These drives can be removable or fixed. Sometimes I am reconnecting to one of the drives, and the drive letter is not the same. I thought there could be a way to access it via the drive serial or some other identifier. Is there any way Directory Opus can be helpful with this?
Try an alias:
The alias system also allows you to refer to drives by volume label (or name) rather than drive letter. The format for this is /$<label>.
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Aliases.htm
Scripts can access the drive serials as well. Might be useful, if the volume name is not accurate enough.
Volume name will smash it for me! Wow! this software... and also you... super friend!
