Hello, when I try directory opus, when I right-click the image and video file, the program will crash
0xc0000005
dopus_lister
0x00007ffec936a719
I want to get some help, English is not very good, please bear with me
0xc0000005
dopus_lister
0x00007ffec936a719
The best place to start is the FAQ:
From the crash log you sent, the crash is happening inside this DLL:
C:\Program Files\Common Files\ACD Systems\PicaView\ACDSeePV.dll
Try updating PicaView first.
If you still see problems, and don't want to uninstall it entirely, you can remove its shell extension using ShellExView (details in the guide Jon linked).
It may also be worth sending the crash log to ACD Systems so they can look at it and see if they have a bug to fix.
