Hi, I'm a directory opus noob, so this question might be stupid.
I want to quickly act on a selected folder. E.g.: play the selected folder in foobar2000. Whats important: I want to do this without using the mouse.
So my first idea was to extend the context menu for folders. I opened "Settings -> FileTypes -> All folders -> Context Menu" and added a new action there ("C:\Program Files\foobar2000\foobar2000.exe" "%1"). When I select a folder in DO, I can press Shift+F10 to open the context menu and then I have to repeat pressing down until I reach the context menu entry and then I have to press enter. Too many keystrokes.
My second solution was to add a custom command and trigger it via Find-as-you-type. So I went to "Customize Toolbars and Keys -> User Commands" and added a command (C:\Program Files\foobar2000\foobar2000.exe {allfilepath}). Now I can start typing ">namofmycommand", but I need to press cursor-down to select the command and then press enter to execute it. The matching command is not selected by default, even if there is only one found.
Its also not acting on the folder that I "select/hover" using the cursor up/down keys, I need to select the folder by pressing ctrl+space first.
Is there a better way to accomplish what I want?
