I am aware of this.
I would like to suggest a useful right-click menu option for a directory--Add to user path and add to system PATH.
I am aware of this.
You can do it using the setx command that's built into Windows:
In Opus, you should be able add something to the right-click menu for folders to run that fairly easily, via Settings > File Types.
