Add "Reverse grouping by default" setting to Evaluator Columns
I’m using an evaluator column to group by. It works well, but I’d like to reverse the default group order.
I know it can be configured in Folder Format > Grouping > Sort Groups, but it needs to be done manually every time (without a saved folder format).
Thus, could you please add a “Reverse grouping by default” checkbox* to the evaluator column dialog, similar to the “Reverse sort by default”, to set the default for each evaluator column?
(*Maybe even a dropdown instead of a checkbox, as the folder format dialog allows “Ascending, Descending, By Member Count”.)
We've added this to the next beta. Thanks for the suggestion!
