Adding/Changing a theme on USB key
Hi all,
Is it possable to import / change a theme on dopus that is being run from a USB key? ie. KODC themes. :smiley:
I don't see why not, although I've never tried it myself.
Have you tried it and found it doesn't work?
Hi Leo,
Under settings, backup & restore are greyed out. If I remember correctly, KODC themes require the use of restore.
When trying to import a theme, I found that KODC themes does not have a theme file (*.dlt).
In that case we're talking about config backups, not themes.
I don't think USB versions can import/export config backups, although they are just a bunch of config files/folders so there's nothing to stop you doing it by hand.
I'm not a fan of the way the KODC "themes" are done using full configurations as they wipe out all the user's settings, toolbars, language setup, etc.
Thanks, I didn't think about replacing folders.
What I would really like to do was suggested by someone in a different thread, that is to create my on "ribbon" menu system.
I don't Know where to start and have never modified DO myself. I appreciate the mods others have been able to do. I am going to look into this.
Thanks again for your advice.
