Hello,
My goal is to have a column that sorts the items by date created, then assigns an index without the numbers adjusting when another column is sorted.
Though the code is incomplete, I tried to write enough so the column would at least appear in the lister.
My process was to create an array of the items within the folder, then use a function to find the position of the item in the array.
Based on Post #2, I have to create my own “IndexOf” function to retrieve that position.
The issue, is based on my code, the function returns the count of all of the items in the folder for the value of each individual item, instead of the position of the item in the array.
My Questions
- How do I get my script to work based on tweaking the function to return the position of the item in the array?
- Is there a better method to writing this script? Especially faster?
- Is there a way which on intuitively understand the sort function for Jscript? Primarily regarding the direction of sort.
The Script
function OnInit(initData)
// Provide basic information about the script by initializing the properties of the ScriptInitData object
initData.name = "Deco Relative Order";
initData.desc = "Created Date Order";
initData.copyright = "(c)";
initData.default_enable = true; // Create a new ScriptColumn object and initialize it to add the column to Opus
var cmd = initData.AddColumn();
cmd.name = "DRelOrder";
cmd.method = "OnRelOrder";
cmd.label = "DRL";
cmd.autogroup = true; // we provide our own grouping information
cmd.autorefresh = true; // refresh column when files change
cmd.justify = "left";
cmd.match.push_back("Yes"); // when searching, these are the only two options
cmd.match.push_back("No");
function OnRelOrder(scriptcolumndata){
var filesenum = new Enumerator(scriptcolumndata.tab.files);
var filesarray = new Array();
i = 0 ;
var z = 0;
relitem = scriptcolumndata.item;
while(!filesenum.atEnd())
filesarray[i++] = filesenum.item();
filesenum.moveNext();
filesarray.sort(function (a,b)
if (a.create > b.create)
return 1
if (a.create < b.create)
return -1
return 0
function arraycontains(array, value){
for(j = 0, k = filesarray.length; j < k; ++j){
if(array[j] === value){
return true;
return j;
//return i;
scriptcolumndata.value = arraycontains(filesarray, relitem) /*function arraycontains(filesarray, relitem){
for (var j = 0, k = filesarray.length; j < k; ++j){
if(filesarray[j] == relitem){
return true;
return false;
//scriptcolumndata.type = Number
//arraycontains(filesarray, relitem)
Thank you,
