Advanced Renamer: Macro Editor not working anymore
Continuing the discussion from Directory Opus 13.0.43 (Beta) now available:
Hitting F2 after opening the Advanced Renamer doesn't put the cursor into the preview list anymore (no matter where the focus is). Checking Macro works, but any editing only affects the first file. The remaining files disappear from the view.
It's likely due to the default F2 hotkey for rename fields:
Not sure how useful that is with the field in the Rename dialog itself, so maybe we should block the edit control from handling F2 so the dialog can handle it instead.
Currently, F2 will activate the preview list if focus is on anything other than the new/old name fields or the presets list (where F2 renames the selected preset).
Ah yes! Changing the control key puts things back to normal. Now I also know why Ctrl-S doesn't save changes to the preset anymore :slight_smile:
Heck! These new keys are everywhere! Scary :wink:
I hadn't noticed Ctrl+S. That's probably another one the dialog should override.
Most of those keys are really for inline rename and just a bonus in the Rename dialog (where you'd be more likely to do the same things in different ways, if at all) so having them override the dialog's keys probably doesn't make sense in general. Should be easy to reverse that.
That's done for the next beta (.45).
