Advanced Renamer Text Color
The problem I'm experiencing in certain scenarios (specifically Advanced Renamer at the moment... could be occurring in similar windows, but haven't made note of it) is black text on black background:
I've worked to discover if this is a windows issue or a Directory Opus issue, and so far unsuccessful.
I have used custom color swatches for windows using wintools.info's classic color panel to modify colors in Computer\HKEY_CURRENT_USER\Control Panel\Colors:
https://www.wintools.info/index.php/classic-color-panel
I've also used it in an attempt to change the Advanced Renamer text color to any color other than black, with no success.
I've tried to do same with color options in Directory Opus, but haven't been able to identify related options.
Secretly hoping I'm overlooking something :slight_smile:
Thank you for your help and support!
If you use hacks to change how only some parts of windows/controls are drawn, this seems inevitable.
The checkboxes on that dialog are all standard Windows checkbox controls so it seems the hack you're using to change the dialog background color isn't changing the checkboxes' label color for some reason. Take it up with whoever wrote the hack. :slight_smile:
(You'd probably need to change the visual style, not just a few colors, for things to look right, at least when using colors that don't work with the visual style.)
You'll run into this problem everywhere that uses standard controls, not just in Opus.
Thanks Leo.
I do feel like a bit of an ass now.
The background is a windows custom color. And it is designated as "ButtonFace". Excuse the gaudy testing color :stuck_out_tongue:
I was deliberately avoiding buttons, thinking only of "Yes" "No" buttons, not thinking the whole dialog was being classified as a "button".
BAD on Microsoft for poor naming conventions! :slight_smile:
I'll still see if I can't change up the font coloring.
Thank you for your time and response!
Hopefully this does help others who experience similar.
Ah yeah, those color names are quite overloaded.
We're hoping to add proper "dark mode" support in the future, including for things like the Rename dialog which you can't currently customize via Opus's own Preferences. The main hold-up is that Microsoft still haven't published any APIs for doing this, and the reverse-engineered ones are still changing in Windows updates, so they don't seem safe to use. But eventually, we hope to add support for it. Microsoft's theme support is really half-baked, and Dark Mode is the most half-baked thing they've done yet.
(Why can't we choose the colors like we used to, instead of just switch between light and dark, and only for Microsoft's own apps? It's ridiculous. But what can anyone do.)
