In the Advanced Renamer, the Clipboard entry Create function from current settings will not use presets but copy all settings verbatim and even include scripts.
Wouldn't having an option that uses the selected preset and hands over the values for SCRIPTARG be nice?
Yes, that's right, but it only generates the command with the preset (which is available via suggestion popup in the button editor). Is there a way to include the options for SCRIPTARG (unavailable via suggestion popup)?
