I need help with an advanced search help.
If I search recursively for a folder named "temp" in the full path, it returns multiple/duplicate results.
it would find
C:\prj\temp
C:\prj\temp\Asset-A
C:\prj\temp\Asset-B
C:\prj\temp\Asset-C
Is there a way to filter this found set down to only list the shared parent folder? When I do a similar search, I am getting 1000 found results, but there are only about 16 parent folders found.
If I were to delete the found set, it tells me an astronomically high warning about to delete 100TB, when really it is only about 7TB, but I assume it is counting every folder multiple times.
Or is there a way to modify the original search to only show parent folders?
I am currently searching for
Match Folders
Match Full Path contains "*temp*"
