The feature to hold Alt and left click a tab to cycle through its lock modes is now not working.
Have I changed a now forgotten setting?
Still works here.
Scripts that change what mouse clicks on folder tabs do could be the cause.
I disabled all scripts and Alt+click on a tab still does not cycle through tablock types.
What happens instead? E.g. if you alt-click an inactive tab, does nothing at all happen, or does it become active instead of locking?
Where are you clicking on the tabs?
Alt-clicking an inactive tab does not make it active or change the tablock type.
I've alt+clicked all over an active or inactive tabs.
Opus 13.22.4, Windows 11 Pro 25H2 26200.8246
Are all Alt+Click actions ignored? E.g. Alt+Click on an unselected file and it should become selected.
Holding down the Alt key and left clicking on an unselected file does not select the file.
I'd say something on your system has taken over Alt+Click on things, or the Alt key isn't working.
(Not as silly as it sounds. I had a similar problem with my Ctrl key recently, until I blew air into the switch. Very confusing when Ctrl-C kept typing a C instead of copying things.)
Might be worth checking if Alt+Click is also ignored in other programs (e.g. File Explorer) to get an idea if it's system-wide or something that's only happening when Opus is active.
@Leo Thanks for your ideas.
Third party software, AlwaysMouseWheel 6.56_64, hijacked Alt+click with no way to turn it off in the settings of the software.
AltSnap 1.67 has the same functionality to move and resize windows with a blacklist option.
