Hi, in the File Types setting, I changed the "All folders" one so that Alt+Double click is go openindual and Ctrl+Double click is go newtab. It works for folders in the main view region.
However, I didn't find a way to change the behaviors of Alt+Single click and Ctrl+Single click on folders in the Favorites and the folders in the location bar (showing the path). Is there a way to change them to the one I specified above as well? Thank you.
Actually, for the favorites, I found the relevant setting at "Folder Tree - Selection Events". Still interested in the keyargs solution though. I found keyargs as part of a command in the documentation, but didn't find a way to put commands in the folders shown in the favorites list (on the left of the window).
