Alt + Mouse Wheel for navigating back/forward?
hi everyone,
as you know you can navigate back and forth using the "Shift + Mouse Wheel Up/Down" but I can't change that shortcut in "customize -> keys". it's not even there, to begin with.
since I generally use "Shift + Mouse Wheel" for "horizontal scrolling", I wanted to have that in Opus too and set "Alt + Mouse Wheel" for navigating back and forth (imo it's more natural to have Alt for it, since "Alt + arrow keys" do the same when both my hands are on the keyboard)
any help would be appreciated🙏🏼
No such option, unfortunately. It's bound to the setting under File Displays > Mouse > Mouse Wheel + Shift to navigate back and forward. If it were adjustable that setting wouldn't be correct or work.
The only thing I could think of is to have some script change it (optionally via AutoHotkey or StrokesPlus). Otherwise it's hoping that it would be taken into consideration to have it as an option in Opus in the future.
Thanks. I hope to see it in the future versions.
