I would like to share my latest Dopus toolbar creation for android devices.
Android Debug Bridge Toolbar (ADB)
ROOTED DEVICES ONLY
What does this do?
*Send a selected file to your phone in 1 click!
*Pull content from your phone to your desktop.
*Install a selected apk from Dopus to your phone.
*Search for a specific package on the device and uninstall it.
*Create a logcat straight to your desktop or phone's sdcard.
*Reboot Device into Recovery mode, Download mode or Fastboot mode.
*Troubleshoot a device if something went wrong. Example: A device that bootloops.
*Capture a Screenshot of your phone and send it directly to the desktop.
*Record Mp4 video of your phone's screen and send it to the desktop. (Requires Android 4.4 KitKat)
*Share your phone's display with a PC using Android Screen Monitor.
*You can start using ADB commands when the boot animation of your device starts up.
and so much more...
Install Java SE Runtime Environment 7
http://www.oracle.com/technetwork/java/javase/downloads/java-se-jre-7-download-432155.html -
Download the Android SDK http://developer.android.com/sdk/index.html (It's huge like 480MBs)
Extract
Keep the android-sdk-windows\platform-tools folder
[broken imageshack link] -
Place android-sdk-windows\platform-tools somewhere like C:\ for example.
C:\android-sdk-windows\platform-tools -
My ADB toolbar will be looking for android-sdk-windows\platform-tools\ADB.exe You must create an environment variable for my toolbar to function.
Go to My Computer>Properties>Advanced System Settings>Environment Variables
[broken imageshack link]Add that line to the very end of the variable value without spaces.
This is what my path looks like for example:
;E:\android_dev_environment\android-sdk-windows\platform-tools\ -
Restart Computer for changes to take effect.
Connect Phone via USB with USB debugging turned on in Settings>Developer Options.
(If you don't see a Developer Option, go to Setting>about tap the build number 10 times.)My ADB Toolbar should work right away. Try the Devices button to see if your device is listed.
You will get a cmd prompt window saying
List of devices attched.
523c53a1 deviceIf you have a device listed, everything else on the toolbar should work.
Go here for more information on the topic. http://forum.xda-developers.com/showthread.php?t=2141817
Note: I haven't tested the Screen Record button yet. I'm currently running Android 4.3.1 on my Samsung Galaxy S3.
Download my toolbar below
Move ADB.dop to /dopusdata/Buttons
ADB.dop (16.5 KB)
