Animated GIF
Hi, I am unable to render animated GIFs with the Viewer, it only shows the first image and there are no additional buttons showing up in the viewer. The Directory DOpus Viewer is defined as default viewer for all image types and the gifanim.dll is present in the Viewers folder. the DO version is 12.32 x64 under Windows 10 Enterprise LTSC version 21H2. What could be wrong?
Under Preferences / Viewer / Plugins, is Animated GIF present and enabled?
Click Configure on it and make sure the two Animation controls... settings are both on.
If that all looks good, please zip and upload the gif you're having problems with so we can try the same file.
A screenshot of what the viewer looks like may also reveal where the issue is (e.g. another plugin handling the file instead of the proper one).
That is, great Leo, the plugin was unchecked. Now, it seems as an obvious place to look at, but you provide so many possibility to configure things that I am still very far for mastering if only a part. Any way, many many thanks.
