I'm aware of the Upload to ImageShack and Flickr buttons, and they've come in very handy. However, does anyone know of a way to upload to different sites, like MegaUpload/Rapidshare and so on?
Thanks!
Thanks!
Good question. Uploading to any file-sharing services from Dopus will be useful.
Not unless they provide a command line tool to upload files which you could integrate into Opus. If you want support for more sites then you could try sending a support request. Although, unless the sites provide some sort of api to allow external tools to upload then it's probably not going to happen.
It must be not Internal command. Maybe someone known something like this tools (code.google.com/p/plowshare/), but for Win32.
