ARCHIVE=.7z and ARCHIVE=single at the same time
I want to create archives where each selected item will be added to its own
archive. The archive’s format should be 7z.
Is it possible to combine ARCHIVE=.7z and ARCHIVE=single?
The 7Zip plugin doesn't currently support this method of operation unfortunately, however we are hoping to add this in the future.
In the meantime you can achieve the same effect using the dopusrt command, for example:
dopusrt /cmd copy {file} here archive=.7z
An answer as fast as a lightning.
Thanks
