It's a bit of a pain to close my lister after using it in the filmstrip mode, to have it open in the same mode when using the drivebar, or opening "My Computer". Is there a way to select an opening style, such as single or commander?
You probably just need to uncheck Mode here:
( Described further in this thread: [Startup folders) )
[quote="nudel"]You probably just need to uncheck Mode here:
( Described further in this thread: [Startup folders) )[/quote]
Disregard my last question. I figured it all out by going into the Folder/Folder options if preferences.
