I use the dark mode and everything is dark except for the dialog windows like the Preferences window or the new folder window. These are still light. Most text and dropdown boxes have a dark background but the text is also black (as is the case in a light theme), so I cannot read anything. It's a mixed bag of light and dark mode.
When I select light mode, kind of the opposite happens with the menus and dropdown boxes.
I looked through all color settings, but I don't see a place to change this.
DO 13.0.44 in Windows 11 22H2 build 22621 in a Parallels ARM virtual machine on macOS 14.
It's a minimalistic installation. When I looked at the installed apps I saw DO 12. I uninstalled this. Then I had to reinstall 13. Still the same issue though.
Oh, and with this reinstall I now use the default settings. I did not yet restore my own.
Another possibility is that the API hooks dark mode requires do not work on ARM/Parallels. Unfortunately, I don't have a MacOS machine to test that with.
If that's the case, wouldn't dark mode work at all? Or do the dialog windows utilize different API hooks than the primary DO interface?
For what's it worth, I never experienced any issues with DO 12. The UI elements were not in the wrong color. But I guess everything in DO 13 is build from the ground up so it's difficult to compare.
Looks like it is to do with ARM. Jon has access to an ARM machine and sees the same on there.
Opus 12 didn't hook the OS to make standard dialogs and controls dark. (Which is still the only way to make it happen everywhere, thanks to Microsoft not actually finishing dark mode in Windows.)
We'll see if we can get dark mode it to work with ARM in the future, but it may not be something we can do before the initial release. A native ARM build may solve things, but has its own complications that need looking into in detail.
While I didn’t expect this to be resolved in DO 13.6.4beta, I hope that we can see some progress in this area, especially considering the increasing significance of Windows on ARM.
Some questions.
Why does the background of the Find files section adhere to the color setting, but the background of Sync and Duplicates does not, and stay all white? I use a bright pink color to illustrate this.
The drop-downs act weirdly, both in light and dark themes, no text is visible. Can you reproduce this on your ARM machine? Or might this be unrelated to ARM?
The attached files were created with my custom theme, which makes some text a bit more readable. However, I can 100% reproduce this with the built-in themes.
I just upgraded to DO 13 on a MS Surface Pro 11 (ARM) and am experiencing the same thing. Most of the dropdown boxes under Settings appear empty as the text is white on white background so am having to try to select the correct option by trial and error. This severely limits my ability to add scripts, etc.
I just wanted to add that I bought a new MS Surface and dark mode doesn't work just like described here. I guess I'm off to using light mode until a fix can be done.
Today was the first opportunity I had to look at it (in version 13.15.2).
All the white backgrounds are now dark, the color can be set to match the pink in the image from June 2nd last year, and the contents of the drop-down lists are clear. So, there are huge improvements.
I haven't found a setting to change the color of the background of the Preferences window or the Find, Sync, and Duplicate panels, but I like the current color.
