I'm working on a dark color scheme for my desktop and I'm trying to get DOP to match it. The lister is a dark gray, but for some reason when I click "modified", "size", or any of the other arrange buttons, the column below it turns bright white. How do I fix this?
Go to Settings Menu > Preferences > Display > Fields and check the option for Current Sort Field in the Fields: list (it should be at the top of the list). Check the Custom color and font settings enabled option, and set the Background color to something closer to your background image.
The only place I didn't check Thanks man!
I'm curious how you changes your scroll bars and field colors. Are you using WindowBlinds or other such software?
