Hi Leo, You're a champ!! Thank you so much.
You know, the AI community has damn-all for useful tools. DO is the best NC-type tool I've used since Norton folded, and I've been doing this for a long, long time.
There a real need in the AI community for file handling tools. The same holds true for the 3D community (ZBrush, 3DS MAX, Poser, DAZ 3D, etc.)
We have tons of files and often very little in the way of useful identifiers, depending on the app.
If there was a plug-in that would identify Stable Diffusion file types and also identify the file's base model, I'd sure as hell buy it.
I can code some, but that work is beyond my skill set. I used Phind.com to make python scripts to help me learn a file's base model, but they're hit or miss. The same holds true for the file's type. Virtually every SD file is a .safetensor (there are some .PT's around), it's just a python compression container (?). I don't have the time or enough skill to modify the scripts to cover the many, many edge cases.
The repos for ComfyUI and InvokeAI have the code to make both determinations. Somewhere.
If someone made a plugin that'd display the useful metadata for the safetensors and it noted the base models, their purpose (LORA, LYCORIS, etc.), and for the Lora and Lycoris types, any triggers or training words, I'd put out a couple hundred for it. Trust me, it would be saleable as a lower price once the people on Civitai hear about it.
