Rename PATTERN=(....)(.+) TO=\2 FINDREP
@NODESELECT
I heard this was the regex way to do it, but I'm missing something.
Help?
@NODESELECT
Help?
My button has this code...
Rename REGEXP PATTERN="....(.+)" TO="\1"
This one (from buttons section) removes x chars from left, second code from right:
Rename TYPE=files REGEXP PATTERN ".(.+)(\..*)#{dlgstring|How many chars to remove from left:}" TO "\1\2" AUTORENAME
Rename TYPE=files REGEXP PATTERN "(.+).(.*)(\..*)#{dlgstring|How many chars to remove from right:}" TO "\1\3" AUTORENAME
You really want the dynamic renamer script!
(shameless plug fun).
It makes it easy to test out substitutions and pattern matches. Here I told it to replace the first 4 characters with nothing:
Thank you sirs. Got it working!
For future visitors, Dynamic Script is at
Well, my ignorance is showing again. I installed ActivePerl 64 bit and imported the latest version of Dynamic Renamer.orp but it does not work for me (see below). In fact, my screen does not look like @MrC since the script appears in mine and not his. Can someone/MrC educate me on what I'm doing wrong. I tried it with both a file and a folder and nothing happens. The reason why I was intrigued is because of the functionality like removing contents within brackets.
I apologize if this is not the correct thread to post to.
thank you,
The first character of all transformations is a dash, not dot:
Thank you. It worked.
Just wondering @MrC, why do I see the Perl script and yours doesn't?
For the screenshot, I dragged the script portion of the window to be minimal size.
