Attr Description for Shortcut
Hi,
my idea is to make a shortcut which has the same description attribute as the file.
So I try to find a way to use makelink and then setattr descrition xxxx
But I need the xxxx from the original file: I tried {desc} as a variable but this did not work
I tested: clipboard set={desc} (similar to set{fil})
but the clipboard contained only the string {desc}
Thanks for help
Marc
