I've used D Opus for a lot of years and I've always had audio bitrates display automatically in the bitrate and description column. Using version 11, it still works on my laptop but not on my desktop. How do I make it display bitrate. I've enabled the bitrate and description column but they remain empty which viewing audio files.
Which type of audio file are you looking at?
Does the bitrate for the same file display on one computer and not the other?
Sorry to hijack thread but I'm having similar problems with most of my media files.
I can't seem to get dimensions, or bitrates to be displayed on the column view.
Could be there another program interfering with it? I can see all file details if I right-click and select properties - but obviously that isn't very useful!
Same questions as above apply.
