Audio files, ID3v2 tags, Language (TLAN), view/edit in Metadata?
Hello,
I have been trying to find if/how DOPUS may view/edit ID3 tag for language (TLAN). Quite useful in Audiobooks (mp3) to identify the language. It would be great to be part of the native DOPUS Metadata view/edit panel but sadly is not. I even checked EXIF (ExifTool Custom Columns - #113 by lxp) but no luck finding ID3 for language either.
Any ideas please? Thank you.
Do you have a test file you can upload here?
I'm not sure about that one, but using this other one, you can see many language related tags.
@errante thanks for the feedback.
It is not that i have any issue with a specific file. It is that DOPUS (The Greatest tool ever!) does not support natively TLAN tags view/edit (unless i am missing something...).
I am also aware of other tools to view/edit ID3 tags (TLAN), such as MediaInfo, mp3tag, kid3, etc, but i would love to stick to DOPUS. One tool to rule them all! I have played a bit with some scripts in DOPUS, failed to write TLAN values with mp3tag and kid3 (due to long-paths and/or filenames containing GR characters) and succeeded only by installing Python and using mutagen (thanks God for vibe-coding!) BUT still I did't manage to find a way to display TLAN within DOPUS.
:thinking:
Sorry, I thought I was talking about Opus too :slightly_smiling_face:
Assuming you did indeed try the script I linked to, without success, a test file would be helpful to know exactly the tag you're referring to.
@errante apologies, I thought you were referring to the MediaInfo Win app. I have installed the MediaInfo**++** script and i can finally view TLAN info within DOPUS! Great work and thanks for the tip!
...possibly the DOPUS native metadata panel will be expanded in the future to include such ID3v2 tags too!
